#55394
Shaneee wrote: Thu Nov 14, 2019 10:01 am Use Terminal to copy the file back,
sudo cp -Rf ~/Desktop/Processors.strings /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en.lproj/
I followed this guide and your guide and it is not working... it still gives me read-only
Screenshot 2020-03-10 at 00.28.31.png (74.55 KiB) Viewed 1025 times
#55404
You've not mounted the root drive correctly. Missing a back slash.
sudo mount -uw /
#56300
My CPU appears as just 3.8 ghz, not intel and not blank. I am running an AMD Ryzen 9 3900X. Is anyone else in the same situation. When I run the command "sudo mount -uw /" in terminal, I recieve the following message: "mount_apfs: volume could not be mounted: Operation not permitted
mount: / failed with 77".
Any suggestions as to what I might be doing wrong. I didn't try either renaming path as I'm not sure which one to follow and don't want to mess up my running system at the appeasement of my OCD.
#56393
Sorry, I forgot to hit submit yesterday lol.
I changed the SIP value like you stated to E7030000; however, I am still just seeing 3.8 Ghz under system details and getting the same error message fro terminal.
Any other suggestions?
