#51484
Got Catalina Running with flying colours.
Everything works except sleep of course
If you are already on Mojave, just replace the config.plist with the new one built for Catalina
Choose 15h_16h for FX, A series and 17 for Ryzen.
If you get panic at AppleIntelMCE put AppleMCEReporterDisabler.kext inside EFI>Clover>kexts>others.
(optional) don't know if it's useful but put SSDT-EC.dsl in Clover->ACPI->patched
If you see "USB Accessory needs power" when you plug in a device change SMBIOS to iMacPro1.1 iMac 19,1
Happy Hacking :thumbup:
Update: Got Sidecar working Followed this post.
Sleep is (still) broken. Got Handoff/Continuity working with TP-Link Archer T6E and Kinivo BTD400.
Hope this helps someone
Screen Shot 2019-10-09 at 7.19.45 PM.png (3.79 MiB) Viewed 3948 times
(1.57 KiB) Downloaded 166 times
(3.02 KiB) Downloaded 142 times
Chmielu, excellence, Egress liked this
#51499
It's easy with the discord server being very helpful.
Follow this tutorial if you don't have access to macOS:
https://vanilla.amd-osx.com/
Follow these instructions if you are on a mac:
https://github.com/AMD-OSX/AMD_Vanilla
by: lhjmmc
#51512
J Bizzle wrote:Keep getting stuck on the ++++++++ bit after I press enter on the drive
Try replacing the drive.
AptioMemoryFix.efi, OsxAptioFixDrv.efi, OsxAptioFix2Drv.efi, OsxAptioFix3Drv.efi. (only keep one at the same time)
#51530
J Bizzle wrote: Wed Oct 09, 2019 8:38 pm Keep getting stuck on the ++++++++ bit after I press enter on the drive
What's your SMBIOS? Give me your system specs.
by: J Bizzle
#51536
my smbios is set to iMacpro 1,1
specs
amd fx 6300
12gb of ram 1333mhz
GA-970A-DS3P
cant remember the rest if you in the amd osx discord just type "$hw @jxathen" then its there
also whats your discord? (so i can contact you easier)
#51598
Sundhar88 wrote: Thu Oct 10, 2019 11:22 am Get the efi. Report back
My bro. Thankyou so much. I am installed Catalina with your EFI. But AppStore is not working. Can you help me?
My sistem information
FX8300
MSI 970
MSI R7 370 4G
