#50660
housereactor43 wrote:thanks! why do you have BIOS FOLDER? shouldn't it be deleted?
Actually it doesn't matter. I have in BIOS boot: Only UEFI. So this folder will never be used. I really suggest you going to amd-osx discord, we could easily resolve your problems in less time due to instant messaging.
#50677
I got banned on discord - someone didn't like my thoughts about vanilla guide.
Anyway I typing from new hackintosh now. I reinstalled everything. and got proper pie wi fi + bluetooth card (works)
My audio doesn't work, and I can't update to Security Update 2019-004
I managed to get the audio working just fine
but I still cant install security update 2019-004 10.13.6 it downloads starts updating and restarts
#51789
Hi, i got my AMD Hackintosh working with this instructions: http://kb.hackintoshisfun.ml - you have to use the offline installer guide.
For Wifi: I use a Dongle from TP-Link (TL-WN823N) and there is a programm which contains the needed kext and a software for the top bar to connect and scan your wifi network. It can be found here: https://github.com/chris1111/Wireless-U ... ter-Clover I used Version 8 and it works like a charm.
The only real problem still existing for me is the Lightroom incompatibility....if someone has an idea how to fix that....i would be very happy.
Hope I could help you.
AMD FX & OpenCore support
Hi Guys and Gals, I'm trying to install Catalina O[…]
Thank you. This kext worked without problems.[…]
Try adding these boot args, shikigva=40 shiki-id[…]
Screen Shot 2020-01-29 at 7.51.53 PM.png Build[…]
