by: pi2in3
#50164
hi guys
I've created vanilla highSierra 10.13.6 USB and Vanilla Mojave 10.14.1 USB on Windows. i can boot and install Mojave but cant boot high Sierra Installer. it got stucks at Apple logo and progress bar beneath. i don't want and cant use Mojave cause of my VGA is Nvidia. beside i have 10.13.3 v3 unofficial.
Any help?
#50166
You signature says you’ve updated to 10.13.6 anyway so why are you going to reinstall?
by: pi2in3
#50169
Shaneee wrote: Sat Jul 13, 2019 10:19 am You signature says you’ve updated to 10.13.6 anyway so why are you going to reinstall?
you'r right but i've not been on 13.3.6 anymore cause it had lags and bugs also random reboot, i just forgot to edit my signature.
would you plz help me?
#50170
So do you have macOS installed at all?
by: pi2in3
#50171
Shaneee wrote: Sat Jul 13, 2019 11:23 am So do you have macOS installed at all?
yes, I have.
#50172
Then why the need to reinstall? If it’s not up to date then simply add the vanilla patches to your config and run the update. This will make the system more vanilla.
by: pi2in3
#50173
Is it possible? Do You mean online update from Appstore or comboUpdate?
Also patches are very to add theme onebyone to config and do i need prelinkedkernel ?
Any instructions?
#50177
Upload your Clover config. I’ll add the patches for you.
by: pi2in3
#50180
Shaneee wrote: Sat Jul 13, 2019 5:14 pm Upload your Clover config. I’ll add the patches for you.
thnks but i did it myself. just check it plz :thumbup:
if so whats do am i do to upgrade to 13.13.6?
(5.81 KiB) Downloaded 6 times
#50181
That’s correct. So now Clover will patch the kernel when booting meaning no more kernel replacements. Just head to the App Store and install the update.
