by: revrites
#49517
Hello, there is a problem with virtualization, when using Parallels Desktop PC it hangs, and VMWare Fusion shows a critical error, how to deal with it, in the BIOS settings, virtualization is enabled?
Ryzen 1800x
Corsair Vengeance LPX 16Gb
Asus CROSSHAIR VI HERO(x370)
Sapphire Nitro+ RX 580
by: kwankiu
#49523
Yes, Parallel Desktop does not work currently, if you have enabled SVM or AMD-V on your BIOS, VirtualBox should work, VMWare seems to be working?? I am not sure for VMWare, but VirtualBox works
#49524
I'm currently using Parallels Business Edition Version 13.3.1 (43365) with no issues :thumbup:
by: lellotrek
#49533
Hi Shaneee parallels build 14.1.2-45485 is not working for me but i will try your build version, virtualbox is working very well but are you enable to virtualizing Mac os older version like yosemite or sierra?
