by: dygkset
#48216
when boot EFI windows bootloader(bootmgfw.efi) read BGRT(boot graphics resource table) form acpi table
BGRT contain address of Bitmap image(usually motherboard vender logo)
So when BGRT and right bitmap image data is exist then Windows efi bootloader draw that image instead of windows default boot logo
Like this
Add description
Add description
Boot moarl.png (12.33 KiB) Viewed 315 times
But some of you see like these when chainload windows form Clover bootloader
Add description
Add description
Add description
Add description
borken ratio.png (6.38 KiB) Viewed 315 times
First one caused by wrong status value in BGRT
second one caused by wrong offset value in BGRT
UEFI set offset value to bgrt offset calculate based on low res boot screen
clover reset resolution to higher but offset inside BGRT does not changed…
you can fix it by using this UEFI application
https://github.com/Metabolix/HackBGRT
to me it works find thanks to Metabolix…
it provide BGRT offset, status, modifi and load custom BMP file
attached moded clover r4934(bootx64.efi) file is ‘hackBGRT’ merged clover r4934
with this version of clover you can use hackBGRT by setting clover custom boot logo setting in
GUI->custom entry->custom boot logo
I think some of you fill more convenient in this way….
Add description
Add description
Set like this
Empty = just fix offset and status value for motherboard logo
Apple = remove BGRT for ‘windows default logo’
\EFI\CLOVER\filename.png = load custom png logo
When entry type is EFI_windows then your order processed by hackBGRT
Else it just work vanilla r4934
Add description
(462 KiB) Downloaded 32 times
