by: Riskypedia
#49836
Facing the same issue. I'm using Vega 56 from Gigabyte and the maximum clock is 800mhz. Very abnormal... I think that's why it's lagging when I hold and drag my mouse at the desktop.
by: anthonydrv
#51043
Hello everyone, have you found a solution to this problem?
I have the same problem with a 1500x ryzen and R9 280x
my max frequency is 150 Mhz
Capture d’écran 2019-09-05 à 22.22.10.png (1.77 MiB) Viewed 287 times
Here is my Geekbench compute test on 10.13.3, my max frequency is 1.10 Ghz and OpenCL score is 107297 https://browser.geekbench.com/v4/compute/3989984
by: XLNC
#51047
You guys need to update the kernel patches .
https://github.com/AMD-OSX/AMD_Vanilla
also join AMD-OSX discord server.
by: anthonydrv
#51052
@XLNC, I have updated to 10.14.6, update clover to rev 5070, update the kernel patches (18G95)
My geekbench OpenCL score has increased but still no hardware encoding, my max frequency is 150 Mhz
Capture d’écran 2019-09-07 à 11.59.24.png (1.97 MiB) Viewed 286 times
edit : problem solved,
I had random crashes also since the update to 10.14.6, I added Nullcpupowermanagement.kext in my clover file : I no longer have a random crashes.
I did another geekbench test and....
In geekbench, my max frequency displayed is always 150 Mhz
Capture d’écran 2019-09-07 à 14.56.41.png (16.26 KiB) Viewed 284 times
I still don’t have hardware encoding (but overall performance of MacOS has increased)
