#47541
Hello everyone and welcome!
I have successfully installed macOS this guide https://forum.amd-osx.com/viewtopic.php?f=24&t=6391.
But with the subsequent replacement of the kernel with https://github.com/Shaneee92/AMD-High-S ... U/releases.
Problem: the keyboard ps/2 works if you reconnect it after start :( .
internet and video, iCloud and iTunes It works!
Web drivers are installed through Clover.
I did not change anything in Clover, using only the files that were in the instructions.
But with errors I used setting clover - debug dsdt, fix mcfg, debud and key npci=0x3000 -f kext-dev-mode=1.
My configuration in the signature!
I attach photo.
Sorry for my English. And I do not understand in hackintosh :?
nbishop8 liked this
#47613
fenixloko wrote: Thu Apr 25, 2019 1:20 am Can you help me? In my installation it gives still error waiting for root device
I would advise you to install the system from a hard disk and not from a flash drive.
in Windows, I used hfs+ paragon to copy files.
#47628
Can you upload your Clover EFI folder with kexts and plist?
Did you use the 10.13.6 kernel from the github?
