#46975
Hi guys this is my pc ryzen 5 and gtx 1050 with high sierra correctly installed and working great. :P :P :P I used a version of mac with xlnc and post install by bronya. for audio drivers I used hdmiaudio.kext and kextbeast. the only problem is that I can't increase or decrease the volume with the keys. for the video driver i used Nvidia web and Cuda. everything works great! the pc is really fast and it never crashes!
for any help or question I'm here.
Best regards, Simone
Omkar Patil liked this
#47395
Can you please link to the files and guide you used. I have a similar system and want to install High Sierra on it.
photofinex wrote: Sun Mar 31, 2019 12:17 pm Hi guys this is my pc ryzen 5 and gtx 1050 with high sierra correctly installed and working great. :P :P :P I used a version of mac with xlnc and post install by bronya. for audio drivers I used hdmiaudio.kext and kextbeast. the only problem is that I can't increase or decrease the volume with the keys. for the video driver i used Nvidia web and Cuda. everything works great! the pc is really fast and it never crashes!
your problem with the russian language at installa[…]
Hello every1 I followed this guide to made OpenCo[…]
@teseraph , A quick look at the Thunderbolt SSDT[…]
10.15.3 install issue
I'm seeing exactly the same error. I did enabled […]
