Have you found a bug with the forum or just want to give feedback on the site? This is the place.
#44322
Hi,
I tried to install YosemiteAMDV2
During installation, I got the screen where I could change language.
Then it said: "Select disk on which you want to install", where I only could
choose the USB itself and no other disks on the computer.
But I could access the menu on top: OS X installer, Archive, change help-programs,...
If I could select the disk, I think it would work.
Any suggestions?
Thanks a lot!!
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
I have a hp6305 with X740 AMD CPU and a Geforce 31[…]
