#45854
Download the following application, https://amd-osx.com/files/IOReg.zip
Save that to file and extract a clean DSDT using Clover. When at Clover boot screen press F4 then boot. Mount EFI and navigate to EFI > EFI > CLOVER > ACPI > origin.
Now upload the saved IOReg file and DSDT.aml from the Clover folder and I'll make a SSDT for you to fix NVME. I had to do the same for mine.
by: AlGrey
#45904
@treysig33, @DerJKM, replace your PCI address (can be found in the bootlog generated by clover configurator)
by: Robert Nguyen
#48465
@treysig33 & @DerJKM I've figured it out, hope it can help:
Screen Shot 2019-06-02 at 11.48.33 AM.png (613 KiB) Viewed 1220 times
Screen Shot 2019-06-02 at 11.48.03 AM.png (62.81 KiB) Viewed 1220 times
Screen Shot 2019-06-02 at 11.47.33 AM.png (139.07 KiB) Viewed 1220 times
AlGrey, ErikW, e97 liked this
by: e97
#52331
Thanks for sharing! Side note: my PciAddr does not match up from the bootlog to DiskUtility but the PCIe root address does
by: tikizondo94
#54255
Back to having this issue again. This time with OpenCore Bootloader. I have added my NVMe device properties and added "internal" built in. But still the drive shows as an external in disk utility. Any ideas how to fix this within Opencore?
#54261
I use a SSDT to fix mine. Is that not what you used on Clover?
by: tikizondo94
#54266
I used Clover/Devices/Arbitrary. Added my pci address for my NVME drive then added built-in "1" data. Worked fine within Clover. I dont see any options like this within Opencore. Or maybe im missing something.
#54268
That's still possible in OpenCore under DeviceProperties.
	<key>DeviceProperties</key>
	<dict>
		<key>Add</key>
		<dict>
			<key>PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)</key>
			<dict>
				<key>AAPL,slot-name</key>
				<string>Internal</string>
			</dict>
		</dict>
		<key>Block</key>
		<dict/>
	</dict>
For example.
tikizondo94 liked this
by: tikizondo94
#54270
Im currently using that method but it dosent seem to make a difference. It shows my NVME drive in PCI devices in system report. Thats all. Still shows external in diskutil.
(2.01 MiB) Downloaded 34 times
Screen Shot 2020-02-01 at 7.36.26 AM.png (1.5 MiB) Viewed 1023 times
#54271
Send me your DSDT and IOReg output.
