by: tikizondo94
#42639
Running 10.13.5 with and having an issue with my new NVMe drive showing as an external device. Any ideas on fixing this? Ive tried all the "usual" fixes, external icons patch, ahciportinjector.kext etc. Am i missing something??
#42640
Have you tried the patch from PikerAlpha?
<dict>
    <key>Comment</key>
    <string>IONVMeFamily Pike R. Alpha Patch#External</string>
    <key>Disabled</key>
    <false/>
    <key>Name</key>
    <string>IONVMeFamily</string>
    <key>Find</key>
    <data>SIXAdAeAiwgBAAAQ</data>
    <key>Replace</key>
    <data>kJCQkJCAiwgBAAAQ</data>
</dict>
by: tikizondo94
#42646
Yes sir, Does not seem to make a difference. Also tried latest AHCIPortInjector.kext just to see if it would do anything. Nothing. Attached are my current outputs if that helps. Thanks Shaneee :)
Screen Shot 2018-09-13 at 3.44.36 PM.png (143.62 KiB) Viewed 2673 times
(1.96 MiB) Downloaded 36 times
(864.25 KiB) Downloaded 38 times
by: ydeng
#42648
Inject "built-in" property to pci2646,5008 (right above IONVMeController) might help.
by: AlGrey
#42649
you can use this patch in your config.plist
Screen Shot 2018-09-13 at 6.19.35 PM.png (111.62 KiB) Viewed 2667 times
by: tikizondo94
#42652
ydeng wrote:Inject "built-in" property to pci2646,5008 (right above IONVMeController) might help.
How would i go about doing that?
AlGrey wrote:you can use this patch in your config.plist
Im currently using that patch and it has not seemed to make a difference..
by: ydeng
#42661
tikizondo94 wrote: Thu Sep 13, 2018 10:59 pm
DSDT/SSDT like the following:
Device(pci2646,5008)
Name(_ADR, 0)
Method (_DSM, 4)
If (!Arg2) { Return (Buffer() { 0x03 } ) }
Return (Package()
"built-in", 1
Or you can write a small kext to do this https://pikeralpha.wordpress.com/2014/0 ... /#comments. On 13.3 this was internal, right?
#42664
Ive never used this drive on 10.13.3 only on 10.13.5. I just got the NVMe drive yesterday. Cloned my 10.13.5 SSD drive and fired it up. Always shows as external.
Im no pro at SSDT compilation. Anyway you could lend me a hand with this @ydeng?
Solved. AlGrey straightened me out :)
viewtopic.php?f=53&t=5185#p42704
(1.96 MiB) Downloaded 62 times
(10.89 KiB) Downloaded 50 times
AlGrey liked this
by: treysig33
#45583
@AlGrey, can you reupload that screenshot, the image is invalid now and im having this same problem.
