#46386
AlGrey wrote:This guide will help you get native usb support for all USB ports on Ryzen motherboards. This will fix your issues with DACs/webcams/mics/BT dongles.
MAKE SURE THAT YOU HAVE A WORKING CLOVER ON YOUR USB DRIVE (usb installer you used to install macOS) AS THIS TUTORIAL CAN FAIL. BOOTING WITH THE CLOVER ON THE USB WILL MAKE THE USB PORTS WORK AGAIN (GenericUSBXHCI.kext is in /EFI/CLOVER/Kexts/**).
Automated version (thanks XLNC)
Spoiler:
1. Open the Terminal app.
2. Run the command :
curl -s -o ~/Desktop/ryzenusbfix.sh https://raw.githubusercontent.com/XLNCs/ryzenusbfix/master/ryzenusbfix.sh && chmod +x ~/Desktop/ryzenusbfix.sh && ~/Desktop/ryzenusbfix.sh
3. Let the script do its magic.
4. Reboot and enjoy
NOTE : If you don't have a functional USB port to operate your MacOS (not keyboard or mouse working), use your bootable AMDHS_installer or HighSierraAMD USB to boot to your installed macOS drive. That will allow you to use your USB ports temporarily . Then you can run ryzenusbfix to fix your USB ports and boot without the USB installer.
Hi!
I do this method but now I can't boot, and the USB give me a error too in the file boot.efi... How can the USB stop working?
I have this from the first time I installed High Sierra on Ryzen and haven't any problem...
Any easy way to fix the USB and Boot to fix the problems?
#47031
I have a problem using this script, after using this script the computer can't shutdown. It always reboot after shutdown a few seconds :shock:
#47798
So, I followed the guide and tried both the newer and older patch. Most USB ports aren't working, although mouse and keyboard are ;) (thank god). Attached are my files, what am I missing?
Thanks!
Edit: I am running a Ryzen 2700x and ASUS X470 I-Gaming motherboard.
Anyone?? :cry:
(606.9 KiB) Downloaded 41 times
#48012
@AlGrey, Thank your for your work! However, I met troubles using the Automated solution under my 10.14.4.
I fellow the instruction:https://vanilla.amd-osx.com/ to install my macOS, everything worked fine except all USB 2.0 ports.
It seems that the USB 2.0 controller is not recognized by the system.
I tried your Automated solution but it did not work, the system just seemed no change.
The problem just exist in USB 2.0 ports while the 3.0 and 3.1 ports are working just normal.
Would you please help me? Thank you!
屏幕快照 2019-05-14 09.32.06.png (187.39 KiB) Viewed 909 times
屏幕快照 2019-05-14 09.31.25.png (234.1 KiB) Viewed 909 times
(4.58 KiB) Downloaded 38 times
#48470
Thanks for this tutorial~finally i success, But something may should be modified:
My os version is 10.14.5.
1.the autoscript is ok, but the script's section which editing config.plist is for 10.14.2 or lower, above these version will not be modified.
2.for me i found the correct modification from "list of patchs" , bottom of "clover configure"->kernel and ...-> KextsToPatch /
3.PMHeart 's three modification, and remove the "MatchOS"
PS:
1.patchs more from https://hackintosher.com/forums/thread/ ... dated.467/
2.may be bug: if turn off bluetooth(usb), it will not be turn on again and other usb device of the same hub will be terminated.
#49820
Running 10.14.5 and just not having any luck. the USB 2.0 controller is not recognized by the system. I just got the PC / Hackintosh – Apple Broadcom BCM94360CD – 802.11 a/b/g/n/ac with Bluetooth 4.0. WiFi works not seeing Bluetooth.
I have attached debug files, have been beating head against the wall. Any help is appreciated. Great job guys on the AMD work...
(1.45 MiB) Downloaded 40 times
(5.04 MiB) Downloaded 38 times
  • 1
  • 8
  • 9
  • 10
  • 11
  • 12
  • 13
