#50980
Hi AlGrey,
I have added Ryzen USB in the MaciASL as a new source, but it didn't show up in Tools->Patch
Please see the attached screenshot
Screenshot 2019-09-03 at 7.10.29 PM.png (163.93 KiB) Viewed 1004 times
#51932
Worked perfectly on my system:
R5 1600 + GA-AB350M-D3H
Thanks :clap:
#52126
Does the fix still work on Catalina?
Tried on 10.15.1 and no luck
#52386
When you have time can you take a look to get it support for Mojave and Catalina please. I really appreciate.
#52663
by: fero-g
#53363
Hi @AlGrey,
I´ve tried every method but I always get the "Root Hub Simulation". I can't save the DSDT.aml file when I patch it manually. On the automated Version it occurs a error on the first method. I don't know what to do anymore.
Thank u in advance
Please find attached my files.
(3.46 MiB) Downloaded 45 times
#53523
@Shaneee
That XLNCUSBFIX.kext partially works for me.
Can you tell me what part of the Info.plist I can tweak for my own board?
Edit: I installed GenericUSBXHCI.kext along side it and all of my USB ports work now!
So for anyone with a similar board to mine (Gigabyte GA-F2A88XM-D3H), you can get 100% working USB by installing XLNCUSBFIX.kext and GenericUSBXHCI.kext to your EFI kext folder and there is no need for ACPI/DSDT patches. Message me if you need a config.plist for Clover and 10.13.6.
by: shuadan
#53857
This worked for me to jailbreak my phone, which is great. But now when i boot into mac os it doesnt seem to work. am i supposed to run this everytime?
  • 1
  • 9
  • 10
  • 11
  • 12
  • 13
