by: hamannz
#3875
Well I've used the given flags but at some point the screen goes black, it seems it loads something i guess because i left it for some minutes and the pc suspends if i hit some key at the keyboard goes on again, but i have no display just Black screen
#3878
You'll probably need to use the bootflag nv_disable=1 then install the web drivers for your nVidia card.
by: hamannz
#3926
Now i got this.
Edit= Just realised that I've used the usbbusfix flag wrong
by: hamannz
#3927
Well i get to boot and install but my USB mouse won't work. I've tried different ports but it is the same
Got stuck here
by: evy0311
#3928
Did you boot with -x?
by: hamannz
#3929
evy0311 wrote:Did you boot with -x?
No, why?
by: evy0311
#3931
Try to boot with -x as a kernel flag to see if that helps. USBLegacy=Off might work as well
by: hamannz
#3936
So my flags should be
USBBusFix=Yes nv_disable=1 -x USBLegacy=Off ??
#3947
The USBBusFix flag includes what USBLegacyOff does. Try this USB Fix instead, viewtopic.php?f=24&t=76
by: crazycyber
#54529
Shaneee wrote: Tue Jul 05, 2016 3:59 pm
hamannz wrote:Well I haven't found any concrete guide on how to install OS X.
That's why you're here :thumbup:
You can find a tutorial to make the USB installer here, http://forum.amd-osx.com/viewtopic.php?f=24&t=20
And for after the install here, http://forum.amd-osx.com/viewtopic.php?f=24&t=80
Me neither can find the tutorial to make a vanilla installation of El Capitan on my laptop.
@Shaneee, do you think you can help me?
