by: XLNC
#36278
[center]HARDWARE MONITOR AMD[/center][/u]
INFORMATION
Version      : 3r173
Cpu Support  : AMD
Developer    : Slice
      - This is used to monitor temps for AMD systems
      - Checkout the Readme file included on how to use it.
      - Install kext files in EFI/CLOVER/kexts/Other/ , no need to install in S/L/E
      - To check what LPC chip you have on your mobotherboard , use AIDA64 Engineer on windows and it will listed under Sensors section.
(6.7 MiB) Downloaded 373 times
traxx37, tikizondo94, CassTsai and 1 others liked this
by: sbres
#40986
I think the file is down :(
by: drmjp93
#42232
The file is not available.
Sent from my ONEPLUS A6000 using Tapatalk
by: LEXXX
#42233
hi xlnc my temp is different in bios is there a reason for this or something I have done wrong?
thanks
by: 34313
#42248
My strix b450-i board uses the ITE IT8665E (ISA 290h) chip.
I tried ITEIT87x.kext which did not work, and gave me only one reading of cpu proximity =0C.
Is there a kext available for ITEIT86X?
by: Devagya_007
#42565
my cpu temp showing 0.
Screen Shot 2018-09-06 at 11.50.40 PM.png (135.58 KiB) Viewed 1215 times
by: AlGrey
#42568
ya that's not updated for ryzen
by: sleikang
#42601
Unable to download file
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>AccessDenied</Code>
<Message>Access denied.</Message>
<Details>
Anonymous caller does not have storage.objects.get access to discord/attachments/249992304503291905/399645660665610266/HW_Sensors_v3r86_for_AMD__slice_branch.zip.
</Details>
</Error>
by: XLNC
#42604
sbres wrote:I think the file is down :(
drmjp93 wrote:The file is not available.
Devagya_007 wrote:my cpu temp showing 0.
sleikang wrote:Unable to download file
<Error>
<Details>
</Details>
</Error>
updated the main post .
new download file version is attached now !
by: sleikang
#42616
[email protected] (170.92 KiB) Viewed 1188 times
<Error>
<Details>
</Details>
</Error>
I have downloaded the latest version from the developer, but the CPU temperature detection does not work.
CPU temperature display 0
[email protected] (170.92 KiB) Viewed 1187 times
