#35222
My busratio is 17.5 and I tried using the boot flag “busratio=17.5” but it wouldn’t boot. If I round it up to “busratio=18” then audio will still be off significantly. How would I set my busratio correctly?
#36207
PhatTraktor wrote:my processor is a fx core back edition 4.0 ghz that busratio should I put in org.chameleon.boot.plist
If you use Enoch yes. The bus ratio flag goes under kernel flags in the org.chameleon.Boot.plist file.
#36223
busratio 20?
with this I still have audio cuts in usb 3.0 which is the only usb that turns on roland quadcapture
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>BlackMode</key>
<string>Yes</string>
<key>Quiet Boot</key>
<key>CsrActiveConfig</key>
<string>103</string>
<key>EHCIacquire</key>
<key>EthernetBuiltIn</key>
<key>Kernel Flags</key>
<string>busratio=20 npci=0x2000 npci=0x3000 dart=0 -gux_nosleep -gux_nomsi -gux_defer_usb2 -gux_no_idle</string>
<key>UHCIreset</key>
</dict>
</plist>
as they see usb 3.0 does not come out in usb device tree nor the usb quadcapture but if eciede in 3.0 it sounds for a while with many cuts and stops sounding after a while
audio of l aplaca base and audio pci maudio work without problems the problems are with the audio card usb I am desperate
Captura de pantalla 2018-01-07 a las 0.46.47.png (28.5 KiB) Viewed 912 times
#38724
Any alternatives to CPU-Z on a Mac?
