#34735
Setting your busratio and CPU info can help with time running too slow or fast, audio issues, etc. To set your busratio do the following;
Use CPU-Z in Windows to get your CPU and Bus speed. If your non-turbo CPU speed is 3.1 it will be 3100 in the formula. The same for overclocked speed, say it’s 4.3 it will be 4300. Now you take your bus speed as normal and divide the CPU speed by it and get your busratio.
You put your busratio as busratio=31 or busratio=43 in Boot options of clover configurator like so:
Set you CPU speed and bus speed in the CPU section of clover configurator. Set your CPU speed in Hz and your bus speed in Khz. So a 3.1GHz CPU speed would be 3100 and a 100MHz bus speed would be 100,000.
You put your speeds in the CPU section like so:
For those that never used CPU-Z this is where the CPU speed and Bus Speed are located on the screen:
Screen Shot 2017-12-20 at 9.14.42 AM.jpg (71.07 KiB) Viewed 2667 times
Amd4ever, zzmadd, ProjectV8 and 1 others liked this
#34830
Have done it and performance improved in my hack compared to the same clock speed but without the proper busratio settings done in clover
Thanks!!
Amd4ever liked this
#34844
Then if my PC is and AMD FX-4100 3600 (3800 turbo mode=overclock in bios) my bus ratio mus be busratio=36 by default?.
Anyway, if I don't use Clover, can I use bus ratio only in chameleon boot?.
Thanks.
PD: I reset cmos and i see in a hidden parameter of bios VTD and I disabled that item and now must be work fine, vlc and mkv works very fine in HighSierraAMD 13.1.
Could it be because of the VTD that it worked badly?
PD2: I dont use Clover only chameleon.
#34852
Norton287 wrote:yeah you use busratio= in kernel flags section of org.chameleon.boot.plist
Then for my CPU bus-ratio must be busratio=36.
Thank u very much.
#34856
Norton287 wrote:Yes you can use CPU-Z in windows to see the turbo and non turbo speeds, if you overclocked it should stick to one speed.
I don't use windows, i hate the monster, i use Linux.
Thanks again.
PD: This is my org.chameleon.boot.plist.
(1.36 KiB) Downloaded 57 times
