by: Norton287
#28163
Download link:
https://drive.google.com/file/d/17-RHrc3VDgg01fwcWhX154fDeIyRz804/view?usp=sharing
Once downloaded you want to disable SIP with Clover Configurator. Take a note of the original settings as you'll need them to reenable SIP after the installation. To disable SIP here's how:
Now that SIP is disabled you need to restart your system to enable it. Once you've restarted it's time to install the kexts to your system to enable Bluetooth support. Here's how:
Now reboot again to load the new kexts and you should have Bluetooth support on your system. Once you plug in your USB bluetooth dongle reboot.
vinhbaoabc, ProjectV8 liked this
by: Apoken
#30361
Great tutorial. However I am not able to get this to work. - I can see that now, when I unplug the dongle, a line comes over the Bluetooth marker. However, changing the USB port makes no difference...
Any suggestions?
I have attached my config.
(3.31 KiB) Downloaded 44 times
by: Apoken
#30401
Norton287 wrote: Tue Oct 24, 2017 12:11 pm Try this config.plist, reboot with it and try installing them again.
Thanks! - However this did not do the trick.
I was not able to boot ''normally'' - I had to boot into safe mode and still nothing.
So I changed the config. again, and now all I back to normal.
I am getting a new dongle.
by: buptlink
#32837
I tried the 4 kexts, and I can't boot two.My system is 10.12.6, cpu:1700 mb:ausu b350-plus
When I use kext util to install the 4 kexts , I can't boot. I just crash with some bluetooth crash stack messages. OS:10.12.6
Now I got the reason and solution: turn off the "Serial Port" in motherboard bios settings everything goes fine!
by: zzmadd
#35505
The dropbox link has expired
Now,
installed kernel, installed bluetooth fix
And I can now see the bluetooth preference pane, BUT no bluetooth appears to pair.
I think the fix is using the wrong bluetooth adapter.
It's not using the ASUS Broadcom but the Intel.
See attachment
How to tell it should use the other one?
Screen Shot 2017-12-28 at 19.31.58.png (84.83 KiB) Viewed 1671 times
by: bcchang
#37439
I install your 4 kexts. Bluetooth is working.
I have kanex keyboard and magic mouse 2.
BT keyboard is good working..
Magic mouse 2 pairing is successed. But, it don't work. pointer and click don't work.
I had test it with BT usb dongle and Apple native BCM wifi + BT express card.
But, it is same.
What is the probem?
I use GenericUSBXHCI.kext.
by: dpernek
#38852
I have the same problem. Tried two usb dongles, ASUS BT 400 and some kind of LOGILINK, and apple magic keyboard works, but magic mouse 2 does not. It connect but doesn't work.
This is what I get when type command kextstat | grep touch
125 0 0xffffff7f81434000 0x24000 0x24000 com.apple.driver.AppleMultitouchDriver (264.6) 32DD13F2-22E6-3922-A68E-A07E1E1358A4 <52 5 4 3 1>
by: AlGrey
#38855
@dpernek, your specs ?
