We will even help with Linux.
#22499
how would one add clover menu enters for say kali linux (without reinstall) I'd assume that the method is the same o at least similar for all linux distress? even if that means booting into grub then linux it dent bother me I just want to get my distress running along side macOS
#22573
Sure it's possible with Clover. Use Clover Configurator and open your config but make a backup first. Once open head to the GUI tab and add a Custom Entry for each Distro. :thumbup:
#22580
@shaneee for the path does it have to be to the bootx64.elf or just to the folder in general
#22788
I think it's the boot file for the distro on the HDD.
#22797
@shaneee yes it was
Shaneee liked this
@CaseySJ , Cold startup, no display showing on […]
Screen Shot 2019-12-11 at 10.21.14 PM.png After[…]
Virtualization on Ryzentosh
Most of the Virtual Machine related applications o[…]
Exact same issue, get to the disk utility section […]
