#27139
Till last night it was working fine...but i dont know what got changed and i am not able to boot now... but hardrive lights are blinking its just that display is not coming on to monitor.. its surely a nvidia driver issue.... only i can view is ++++++++++++++++++++++++++++++++++++++++++++++
#27140
It's a config issue. If you follow the directions you'll be able to boot.
#27141
please see the attached screenshots... I cant find clover folder inside this installer usb.
shadab khan wrote:is there any specific way to install clover... ?? i just went with the normal default settings...only selected the partition on which my mac os in installed else i have changed nothing...
Watch this tutorial
viewtopic.php?f=24&t=1702
#27145
macOS sierra version 10.12.6
I followed the same instruction as mentioned in link you provided. But same issue stuck with ++++++++++++++++++++++++++++++++++++++++++++++++++++ displayed on the screen.
#27154
Upload you config.plist. In the EFI/Clover folder right click on it and choose compress before uploading it here. I'll have a look at it.
