#18949
You can install OSX Sierra?
My CPU is FX8300, but, don't have Graphics Card now, i buy the GTX 1050TI 4GB.
#34178
jowocomb wrote:which image you are using, I was unable to proceed with any installation for MAC OS Sierra.
My config:
FX8300
M5a78l M Plus USB 3.0
8GB DDR3 1866
GTX 1050ti
try my new AMDHS_Installer v2
http://forum.amd-osx.com/viewtopic.php?f=23&t=2948#p33500
#34243
Stanciu Alexandru wrote:I have a problem, i get no signal after post install, any fix ?...
PM me I have a clover based installer for radeon cards with instructions.
#48371
Hello mikiszx, yes, with the Hardware you have, it should by possible. I have a ASUS with the same Chipsets and I'm running from Yosemite to High Sierra all Versions of Hackintosh. But with the "amd phenom tm ii x4 965" you only can run upto ElCapitan, because Sierra and higher needs an FX or Ryzen with SSE 4.1 and SSE 4.2 CPU Instructions. Greetings from Germany
#50266
i'm using this installer but after verbose boot mode get stuck at black screen, any solution ?
my build spec this :
System Manufacturer: BIOSTAR Group
System Model: TA970
BIOS: BIOS Date: 03/12/14 15:27:55 Ver: 04.06.04
Processor: AMD FX(tm)-8150 Eight-Core Processor(8 CPUs), ~3.6GHz
Card name: AMD Radeon HD 7800 Series
Chip type: AMD Radeon Graphics Processor (0x6819)
I have the exact same motherboard, 3600X and the[…]
What BIOS are you using? I'm having the same iss[…]
Catalina running but no Internet
you don't have to set manually, just use DHCP
internet problem
do you have rt8111.kext in Others folder or Kext f[…]
