Have you found a bug with the forum or just want to give feedback on the site? This is the place.
by: Ackados
#14894
Nice! :thumbup: I'm not sure if you programmed the front/home page, if so, what is your method of scaling/changing the shapes of everything when the browser window is scaled down, or larger? I'm making a website, and am kinda stuck on that part with a good working method. :P
#14906
I used Bootstrap as a base for it. Add this in the <head> tag and it should give the same function.
<meta name="viewport" content="width=device-width, initial-scale=1">
Ackados liked this
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
I have a hp6305 with X740 AMD CPU and a Geforce 31[…]
