by: ksxi
#56976
Hi all,
I've successfully installed MacOS onto my Ryzen system, got wifi & bluetooth working and all that good stuff
Whilst using it today, I've noticed a lot of stability issues:
Frequent short freezes of system, no matter what I'm doing, the screen will freeze for maybe .5 seconds and then will catch up with anything I was doing (like moving mouse, etc)
Bluetooth will sometimes completely disconnect my MX Master mouse (not sure if this is related to the first issue)
USB Audio Interface, constant static noise coming through speakers( quiet but still there) and sometimes completely freezes, not letting me output audio.
My SMBios is set up as MacPro7,1 if that is a factor for anything lol
Attached is a screenshot of my Kext folder and a copy of my config.plist
Screenshot 2020-04-28 at 21.23.51.png (153.79 KiB) Viewed 1579 times
If anyone could help, that would be amazing!
Thank you all
(6.6 KiB) Downloaded 63 times
#56980
Upload your full EFI and I'll make some changes. Also test the EFI I upload on a USB just in case before replacing your current one. One more thing, are you concerned about your Serial for iMessage etc? I'll change you over to iMacPro as I've found it to run smoother.
by: freeubi
#56983
Don't use those memory kexts, they are unnecessary. You will get the warning but that does nothing.
Also, don't forget to use usb power fix, that the issue on the usb audio interface.
iMacPro is better but you won't get hardware encoding/decoding on that, so :/
by: mindquest
#56996
freeubi wrote: iMacPro is better but you won't get hardware encoding/decoding on that, so :/
@freeubi A newb here so wondering just what you meant by the iMacPro won't get hardware encoding/decoding?
Thanks!
by: ksxi
#57057
Shaneee wrote:Upload your full EFI and I'll make some changes. Also test the EFI I upload on a USB just in case before replacing your current one. One more thing, are you concerned about your Serial for iMessage etc? I'll change you over to iMacPro as I've found it to run smoother.
Sorry for the delay, been super busy - attached is my full EFI partition.
Thanks for your help
freeubi wrote:Also, don't forget to use usb power fix, that the issue on the usb audio interface.
Just had a look around, I couldn't find a kext called that, do you mind attaching it? Thanks
(5.41 MiB) Downloaded 67 times
