#55435
Has anyone had this problem with Davinci Resolve 16.2? With previous versions it worked perfectly, but now it locks in the program load and does not start ... I have tried doing uninstall completely clean but it does not work either.
My Hackintosh
Asus TUF x570
Ryzen 3900x
Vega 64
32Gb Ram
Opencore 055
Kexts:
NullCPUPowerManagement
lilu
RealtekRTL8111
USBInjectall
VirtualSMC
WhateverGreen
AppleALC
#55441
What OS version are you running?
#55442
I have the same problem on the newest Catalina, 3900X, Saphire RX580 Pulse with OpenCore. I installed version 16.0 and works so far.
#55460
HackeyMac wrote: Wed Mar 11, 2020 8:02 am What OS version are you running?
Catalina 10.15.3 Later I will add information about the Davinci Resolve error, and please, be patient with me, it is my second hackintosh, the first I did it about 10 years ago and it did not go very well, this time so that everything is better and I don't know much about macOS no technicalities in hackintosh, I have followed the Vanilla Opencore guide
puciak wrote: Wed Mar 11, 2020 8:35 am I have the same problem on the newest Catalina, 3900X, Saphire RX580 Pulse with OpenCore. I installed version 16.0 and works so far.
have you tried with version 16.1.2? this works for me
#55513
Probably 16.1.2 will work, I just tried 16.0 to see if that would make any difference.
#55523
Thanks it worked! The truth is that I do not know what matlabs is (I searched on google but I did not see anything related), how did you know that it was solved with this? I'm curious
#55524
It's from this thread: viewtopic.php?f=6&t=6964
I thought it looked a lot like the Davinci Resolve 16.2 problem so I just tried it. Because there are no problems with 16.2 on Intel Hackintoshes it had to be AMD related, just like this MatLab issue.
I guess it's just dumb luck it actually worked.
I haven't checked much of Davinci Resolve 16.2 with this patch applied yet. It still might crash on some other point.
#55525
:clap: :clap: :clap: :clap:
