by: Buris Bunch
#55382
I can never boot into installation screen. This is my opencore config.plist.
https://drive.google.com/open?id=1h7WWi ... nl9VSuZThT
I used to use clover but it always freeze at End RandomSeed ++++++++++++++++
So I switch to opencore. Now I can see the second boot screen, but I reboot the computer immediately.
It flash really quickly so the image is blurry, sorry about that.
My configuration is:
CPU: Ryzen 7 1800X
Motherborad: ASUS ROG CROSSHAIR VI HERO
GPU: Radeon R9 380 4G
RAM: 16GB DDR4 2400
by: winterwolf
#55618
Have you made sure you've removed all the bits of clover. According to the install guide, it can leave stuff in the NVRAM and you need to clear that out. Believe there is a clear nvram tool in opencore somewhere.
