by: Matthew Harrison
#54773
Hi all,
I'm having a bit of trouble trying to get my Mojave installer to boot. I've attached the image with my error.
System
CPU: Ryzen 3 3200G
Motherboard: ROG Strix B-350F
Ram: Corsair Vengeance 8GB 3000MHz (x2)
- Tried a few different configs but revert back to the vanilla master posted in the tutorial
- Tried setting my SMBIOS correctly for my RAM configuration
- Tried both RAM sticks in different spots
- Tried 1 RAM stick in all 4 different locations
- Tried changing between different osxaptiofixdrv
There's probably more I've tried but I'm starting to loose it and need a bit of help to figure this one out.
#54774
OpenCore or Clover? Also did you include the AMD patches in your config?
#54775
Sorry, wasn't clear about the boot loader. I am using clover boot loader, latest version. I've copied the patches to the config via Xcode.
We are referring to the patches in the vanilla master from github, correct?
#54776
What version of Mojave? Clover patches only support Mojave 10.14.6 (18G84, 18G87, 18G95, 18G103)
#54778
That's why then. Again Clover patches only support 10.14.6. Follow the vanilla guide and give Catalina a go depending on your GPU of course and use OpenCore. https://vanilla.amd-osx.com/
Matthew Harrison liked this
#54779
Shaneee wrote:That's why then. Again Clover patches only support 10.14.6. Follow the vanilla guide and give Catalina a go depending on your GPU of course and use OpenCore. https://vanilla.amd-osx.com/
Wow, just looked at the guide & now see that. Would it be possible to install using OpenCore? Not as familiar with that, but would give it a go before downloading Catalina.
If not I'll likely just give Catalina a go.
Only asking because I noticed the version under OpenCore is 10.14.*
#54790
OpenCore supports all version of 10.13, 10.14 and 10.15
#54796
Shaneee wrote:OpenCore supports all version of 10.13, 10.14 and 10.15
Ok, thanks for your help, will post results!
Shaneee wrote: Mon Feb 17, 2020 2:03 pm OpenCore supports all version of 10.13, 10.14 and 10.15
Ok, so I managed to get OpenCore to start the boot into the installer, but before I even get to the installer I get basically the same error I got in the first picture.
Start LoadRAMDisk
EndLoadRAMDisk
Start FinalizeBootStruct
Start RandomSeed
End RandomSeed
Any thoughts?
