by: TYD
#10622
Hello,
I want to ask about the support of the Radeon HD 7870 in Mavericks.
Is there any kext to install to get the full graphics acceleration.
Greetings
#10631
Is the device ID 0x6810?
by: TYD
#10640
Where can I find the device ID ?
#10642
System Information or Device Manager on Windows.
by: TYD
#10643
#10647
Strange the ID I found for the 7870 was 0x6810. It should be compatible you just need to inject the Device ID into the correct kexts. It should be AMDRadeonX4000.kext and AMD7000Controller.kext. If you don't know how to just upload those two and I'll edit it for you.
by: TYD
#10651
Look, the same device ID as mine:
https://www.techpowerup.com/vgabios/119327/ati-hd7870-2048-120209
Should I post the two kexts from my Mavericks installation ?
#10652
Yeah upload them and I'll add the device ID 0x6818
by: TYD
#10667
Here:
https://drive.google.com/uc?export=download&id=0B2J0lmfHDIeUbE8tckI3WlN5Vk0
#10670
Ok so it seems the device ID is already present there. Are you using Enoch or Clover?
