by: Shane Jacob
#6517
Hey I've made 10.9.5 with myhack which completed successfully. After that I replace the kernel with BSA_10.9.5_FX_rc1.
The bootflags that I use are GraphicsEnabler=No npci=0x3000 PCIRootUID=1 -v but at last I get stuck at built-in decrypter used. I'm attaching the picture any help will be much appreciated. Thanks.
System Info -
AMD FX 4300 Black edition 4.2 GHz
Gigabyte GA-78LMT-S2P
16 GB RAM
Gigabyte Nvidia Geforce GT710 2GB.
#6527
See my post to you here, viewtopic.php?f=9&t=11&p=6526#p6526
