#5960
Are you using the integrated GPU?
#6036
Integrated AMD cards won't work I'm afraid. There have been no reports of fully working integrated AMD APUs. A dedicated GPU however would work.
#25035
@bhavesh, You can try with this for the dedicated card,
http://www.insanelymac.com/forum/topic/291117-how-to-make-radeon-desktop-or-mobility-be-working-by-using-clover/
