by: Norton287
#28552
The images aren't showing
by: ToxicBite
#28562
https://drive.google.com/open?id=0B6tez ... lhFUmM3RWs
https://drive.google.com/open?id=0B6tez ... 0MtUC0tSXM
https://drive.google.com/open?id=0B6tez ... 0daSGlBM0U
But it helps me not out! Same problem
like this one
https://drive.google.com/open?id=0B6tez ... er][b]Post Merged[/b]
[/center]so i burn the USB and now it shows me EFI folder and so But if i boot from usb and do use first line like sierraAMD it comes to same problem kernel debugger called panic Backtrace (CPU 4) but after restart and trying again same panic but cpu 0 or 1 or 2
by: Norton287
#28563
Boot with the flag UseKernelCache=No
by: ToxicBite
#28564
how i cant type anything!?
do i should to do that in clover boot option!?
try that and post what comes out!
by: Norton287
#28565
Yes
by: kokos
#34395
hi !i am trying to install mac os mavericks on my pc,motherboar msi 970 ail kret amd fx 8370e and ati radeon hd 3800 and when install writes Backtrace (CPU 4 or other like 1 or 2)but i cant write in clover the up flag!
by: Norton287
#34396
you have to go to Options - Boot Args and hit enter twice to add a flag
by: Norton287
#34404
To boot without cache highlight MaverickAMD, hit the space bar and downarrow to -f and hit enter to select it. The up arrow to Boot with Selected Options.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
