by: ToxicBite
#28534
I dont have any EFI folder and after burning USB i cant see it so i hear that soud that my usb drive was in usb port but i cant see it
by: Norton287
#28536
After you burn it in windows, unplug it and replug it it should show EFI as the drive.
by: ToxicBite
#28540
but it does not show! i can see my USB drive only with transmac
i think i have wrong transmac settings!
by: Norton287
#28541
Then download this one it already has the USB fixes installed
 https://www.dropbox.com/s/2kiytlxh7kl49b0/SierraAMD_V5.2.dmg?dl=0
by: ToxicBite
#28544
okay thx
what is in general settings on transmac?
Disc and Image i have Access non-removable method (use with caution!)
In general i have nothing checked
and DVD/CD Burning i have nothing checked
by: Norton287
#28546
I'm using transmac to burn 5.2 to my usb to test, soon as it's done I'll tell you
In Transmac general this is what I have:
Is best not to mess with the settings, just right click the USB and choose Restore Disk Image
Transmac General.jpg (67.72 KiB) Viewed 402 times
by: ToxicBite
#28547
Okay thx Norton287
So i try it now with 5.2v
by: Norton287
#28548
Ok let me know what happens :thumbup:
by: ToxicBite
#28549
i have
In General settings was nothing checked so the screenshot is wrong so it was made after i check all
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
