by: Locus
#26624
Hey everybody,
My installer stops after the USB Posts. I tried to change the USB Port from 2.0 to 3.0 and from 3.0 to 2.0, but that didn't worked. I have a AMD fx8350 and an Radeon r9 390x. Please help.
Locus
by: Norton287
#26625
Are there any messages on the screen?
by: Locus
#26657
@Norton287,
No. First I must choose Sierra installation. After that at the screenwhere many messages. Among other things the USB posts. And after the writing turns into weird writing and in the middle of the screen is a sign like a Passage prohibited Sign.
Picture with USB Posts:
http://prntscr.com/gicfvl
Picture of weird writing:
http://prntscr.com/gicf7l
by: Norton287
#26658
In the installer try choosing the Rx video card one, from the configs section and then boot sierraamd.
by: Norton287
#26660
You had a kernel panic. Is there a generic config in the configs section?
by: Norton287
#26662
what options do you have I haven't messed with the new installer yet.
by: Locus
#26663
@Norton287,
all options in the configs file are: config, config_InjectAMD, config_RX_480, config_NVIDIAWeb and config_InjectNV
by: Norton287
#26664
try config_InjectAMD
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
