by: Shane Jacob
#6676
Shaneee wrote:Yeah same folder as before and use the bootflag again. Leave the kexts for now.
Still no luck. I copied them in system/library/extensions. Do I need to do any additional step after that like fix permissions or something? I'm attaching a picture of the bootflags that I use.
#6677
Hmm not sure as to why it wont show then. As Mavericks is older replace UseKernelCache=No with a simple -f
by: Shane Jacob
#6678
Shaneee wrote:Hmm not sure as to why it wont show then. As Mavericks is older replace UseKernelCache=No with a simple -f
Alright will try. If only I could remember the kexts which I used two years back.... They were named something like AHCI I'm not sure. But all my hackintosh files were lost after my old hard drive died.
#6679
Was it this one maybe?
http://www.insanelymac.com/forum/files/file/436-ahciportinjectorkext/
by: Shane Jacob
#6680
Shaneee wrote:Was it this one maybe?
That does sound familiar. Lemme try and I'll let you know. Is there any chance that I can install yosemite on this configuration?
#6684
Yeah Yosemite will work :thumbup:
by: Shane Jacob
#6689
Shaneee wrote:Yeah Yosemite will work :thumbup:
Okay update-
I managed to get it working. Turns out it had nothing to do with the kexts. :D :D
Those who have this same board and in future face the same problem -
*Now this is what I did. After a lot of frustration I at last again went into BIOS to double check AHCI mode. And it was enabled. But just under OnChip SATA type which I had changed to AHCI, there was another option OnChip SATA Port4/5 Type and it had IDE mode selected. I changed it to SATA type and tada it worked. My hard drive came up in the installer. Attaching the picture to help.
@shaneee Can I later Dual boot mavericks and yosemite?
Thanks for all your help. Will install tomorrow and update the status.
#6690
Ahh so your board has different options for the different versions of SATA. Yeah I've got 10.6 to 10.10 all installed on the same drive so you can have both.
by: Shane Jacob
#6712
Shaneee wrote:Ahh so your board has different options for the different versions of SATA. Yeah I've got 10.6 to 10.10 all installed on the same drive so you can have both.
Okay update -
I have installed mavericks now but have problem with sound. Attaching the pictures below. Have tried VodooHDA kexts but don't work.
My sound device is - Realtek ALC887
#6803
Try this version of VoodooHDA,
http://amd-osx.com/files/VoodooHDA.kext.zip
