#6617
Add these two kexts into Extra/Extensions
(55.22 KiB) Downloaded 23 times
by: Shane Jacob
#6637
Shaneee wrote:Add these two kexts into Extra/Extensions
Still no luck. I remember the last time when I had the old mobo GA-M68M-S2P and it did not have AHCI mode in BIOS, I had a hard time getting the hard drives to show up in the installer. But that was 2 years back and I don't remember those kexts anymore. Is there anything else that I can try? I thought that I would not need any kexts now as this new mobo has AHCI mode enabled in the BIOS.
#6650
Do you have kernel.plist in the Extra folder? If not those kexts won't load.
by: Shane Jacob
#6655
Shaneee wrote:Do you have kernel.plist in the Extra folder? If not those kexts won't load.
Oh no I do not have it in there. What should I do?
#6656
Add those kexts to /System/Library/Extensions then and boot with UseKernelCache=No
by: Shane Jacob
#6657
Shaneee wrote:Add those kexts to /System/Library/Extensions then and boot with UseKernelCache=No
Okay will try and let you know.
by: Shane Jacob
#6665
Did that but still my internal HDD not showing up in the installer. It does detect my 1 TB USB external drive.
#6667
Did you use the bootflag? Try these kexts then,
(45.69 KiB) Downloaded 25 times
by: Shane Jacob
#6670
Shaneee wrote:Did you use the bootflag? Try these kexts then,
Yes I did use the bootflag and these kexts should I put in system/library/extensions? And do I still need to use the bootflag with these kexts? Should I remove the other kexts?
#6672
Yeah same folder as before and use the bootflag again. Leave the kexts for now.
