by: sphoenixp
#17
CPU: AMD FX 8350
Motherboard: Gigabyte GA-78LMT-USB3
RAM: Kingston HyperX 8GB
HDD: WD Green 1TB & WD Blue 1TB
GPU: XFX AMD ATI Radeon HD 5670
Installed OS': Windows 10 Pro
Stuck on creating a bootable USB. Dont have access to a MAC. olarila 10.9 is downloaded. Have a 8GB PD with TransMAc also installed.
#18
I'm not familiar with the Olarila image. First thing you will need to do is restore the image to your USB with Transmac. Once you have it on the USB, replace the default mach_kernel with the Mavericks one from here, http://forum.nova-x.co.uk/viewtopic.php?f=14&p=9#p9
Once that's done you can try boot. Start booting from the USB and assuming it uses Chameleon as the bootloader use the following boot arguments,
-f -v npci=0x3000
You should now be at the installer. If not message back here. If you get there great, install it and come back and let me know so I can guide you through the next part as it won't boot without some help.
by: sphoenixp
#19
Shaneee wrote:I'm not familiar with the Olarila image. First thing you will need to do is restore the image to your USB with Transmac. Once you have it on the USB, replace the default mach_kernel with the Mavericks one from here, http://forum.nova-x.co.uk/viewtopic.php?f=14&p=9#p9
-f -v npci=0x3000
It uses Clover.
also how to do hfs+ partition with windows. i have 300GB drive free but it is partitioned in windows.
#20
I highly recommend you use a seperate hard drive for each OS. They can interfere with each other.
by: gazza35
#2703
Use win32 disk imager to burn raw image to usb.
Just remember. the OLARILA raw images are for Intel Pc, not AMD, so you may end up having a whole load of issues.
by: Shane Jacob
#6503
Hey I want to install Mavericks on my system. The configuration is -
AMD FX 4300 Black edition 4.2 GHz
Gigabyte GA-78LMT-S2P
16 GB RAM
Gigabyte Nvidia Geforce GT710 2GB
I have restored the image with transmac and I want to know how to replace the stock kernel with the AMD kernel. I do have a working Mountain Lion in Vmware is that would work. Thanks in advance.
by: Valkiry
#6507
You should be able to mount your Partition and copy the kernel over via your virtual machine. If not use Paragon HSF+ to mount Osx extended file Systems
by: Shane Jacob
#6516
Okay hey I've gone through all of that. After that the bootflags that I use are GraphicsEnabler=No npci=0x3000 PCIRootUID=1 -v but at last I get stuck at built-in decrypter used. I'm attaching the picture any help will be much appreciated. Thanks.
#6526
The problem is the GPU. Boot with nv_disable=1 to load the system then run this app to download and install the nVidia Web Drivers. Then reboot with nvda_drv=1
www.insanelymac.com/forum/files/file/474-nvidia®-webdriver-updaterapp/
by: Shane Jacob
#6598
Shaneee wrote:The problem is the GPU. Boot with nv_disable=1 to load the system then run this app to download and install the nVidia Web Drivers. Then reboot with nvda_drv=1
Hey Okay thanks a ton with your bootflag I was able to reach the installation but now it does not detect my hard drive. I have enabled AHCI mode in BIOS but still. this is my HDD - WDC WD10EZEX-00WN4A0 1 TB. I've attached the picture.
