by: Olaf Neumann
#43970
Hello Forum,
I have a problem to install Yosemite with this Image (viewtopic.php?f=23&t=1201).
I use a USB 2.0 Port and these flags: -v npci=0x2000 PciRoot=0
I searched for this Error here, bu the Problem appears mostly by installed Yosemite.
Has somebody maybe a Solution?
Regards, Olaf
PS: By the way, I have no Bluetooth, maybe I could remove the Kext for Bluetooth?
by: RENO
#44032
Olaf Neumann wrote:Hello Forum,
Regards, Olaf
Try this npci=0×3000
Sent from my SM-G935F using Tapatalk
#44104
Hello RENO,
thanks for your Answer, but it didn't help. Somebody gave me the Tip to change Graphikcard, so it will work out of the box.
I have an old GT 220, that works with the Bootflag "GraphicsEnabler=Yes".
Regards, Olaf
by: RENO
#44106
Olaf Neumann wrote:Hello RENO,
Regards, Olaf
Ok... enjoy the hakintosh... this my pc i use yosemite toImage
