#28955
this is not a problem. Please provide asked information
#29170
@eatTheBush, Download the modded kexts below + Lilu and WhateverGreen
https://github.com/vit9696/WhateverGreen/releases
 https://github.com/vit9696/Lilu/releases
Install AMD8000Controller.kext, AMDRadeonX4000.kext, Lilu.kext and WhateverGreen.kext with Kext Utility.
(4.76 MiB) Downloaded 38 times
#29172
@Algrey I installed all the kexts with kext utility but everything is still the same , still don't have graphics acceleration.I don't know where did I go wrong.
#29184
Open terminal
kextstat |grep as.vit9696
kextstat |grep AMD
. Copy the output here.
#29220
The kexts are not loaded. First, delete the files AMD8000Controller.kext and AMDRadeonX4000.kext in /System/Library/Extensions. Second, reinstall the provided kexts in previous post. Reboot and check with kextstat |grep AMD. If not working, consider installing Clover to use FakeID.
#29222
Do you know why am I getting this? It seems like sometimes it boots ,most of the time it doesn't.This is happening after I installed all the kexts including for sound and internet. Note I'm using macos 10.10.5 btw. And nope no luck tried reinstalling kext.can you tell me how to install clover ? And add fake Id to it.it'd be great if you could help me out with that.
Oh. The kext were explicitly marked for Sierra.... I hope you have a backup of the original AMD8000Controller and AMDRadeonX4000 kexts.. Or still have the installer files because I don't have them.
