by: dagalb
#53701
Ok. So after a long night of troubleshooting it all came down to a conclusion. 4g decoding setting messes up with my dual boot setup.
If it is enabled - Hackintosh will boot. Windows 10 will not. If it is disabled - Windows 10 will boot while Hackintosh would not (gets to the boot loader and then gets stuck on the apple logo). My setup is ryzen 3700x with R9 280 on B450 Elite. Any ideas? I'm running on OpenCore.
Thanks a bunch.
by: pdq
#56912
bjar wrote:I had to do the same, except my windows 10 would boot, but Ethernet would not work. Weird...
i have same issue with ethernet
