#56901
Hi all
Sound and etc work only after sleep not wake
İ think my USB port have a problem i try make a mapping but i dont understand guides
its my EFI
https://dosya.co/bb2y470zpivm/EFI.zip.html
And My IOREG in attch...
My usb ports have a problem?
İ make my usb mapping my system sleeping but not waking
What the problem?
Screen Shot 2020-04-27 at 14.41.17.png (345.7 KiB) Viewed 653 times
(708.43 KiB) Downloaded 35 times
#56940
It's rather simple if you're not over the port limit like it seems the case. Take a USB 2 device (like an USB Bluetooth/mouse dongle, old USB Stick, USB Keyboard etc) and a USB 3 device (most USB sticks) and stick each in every port. Simply select the right port type.
After all ports are set correctly click on the export icon (the right most below the list). This usually generates some SSDTs and an USBPorts.kext. You don't need the SSDT-UIAC, just put the kext into your boot loader.
#56946
@_HAI_, exactly. The naming of the column is a little misleading in that regard. Mind there are also separate types "Internal" for internal ports (like Bluetooth etc) and Type C (as they also are somewhat special compared to standard USB2/3 Type A ports)
#56948
Apophis wrote: Tue Apr 28, 2020 8:09 am @_HAI_, exactly. The naming of the column is a little misleading in that regard. Mind there are also separate types "Internal" for internal ports (like Bluetooth etc) and Type C (as they also are somewhat special compared to standard USB2/3 Type A ports)
My ports schema and my usb mapping is here but sleep still not working?
Maybe its about XHC0 ?
Screen Shot 2020-04-28 at 13.20.22.png (350.57 KiB) Viewed 639 times
#56951
Apophis wrote:What exactly does not work? You were not very specific.
When go to sleep; display, keyboard and mouse offing... (Using PRT1 and PRT4) but fans not stoping.. I try wake but not waking again. Display is black mouse and keyboard leds not turn on again.I have to reset i see open screen kernel panic error..
#56953
Your Keyboard and Mouse have RGB, that also has some internal USB capabilities. Maybe try with only a plain USB Mouse to go to sleep.
#56954
Apophis wrote: Tue Apr 28, 2020 11:21 am Your Keyboard and Mouse have RGB, that also has some internal USB capabilities. Maybe try with only a plain USB Mouse to go to sleep.
Yes i try with plain USB mouse its work
How i fix my Keyboard and Mouse Leds? Make This ports İNTERNAL?
