#56542
Evening. Installed Catalina 10.15.4 on my Ryzen 3600/Asus B450M Plus Gaming/XFX 5700 DD Ultra.
Was happy (everything works just fine) til noticed some strange audio stuttering when playing YouTube videos in Safari.
Later I found out how to reproduce stutters — moving app's windows rapidly (every time), open apps and web pages (sometimes) causes same lags. But sound not the only thing lags — picture lags for a moments too. Seems like whole system does.
Also have poor GPU performance (36570 OpenCL / 43325 Metal). So I guess some problem with gpu causes problem with stutters. Some saying that this problem is common for Ryzentoshes, but I can't believe such a talented community still has not solved the problem.
Thanks for your advices. Have a nice day.
#56565
Hey I do have some lagging and stuttering issues with my build as well mostly when gaming and its smooth then a little stutter every now and then. Looking through your EFI I don't have the AGPMinjector.kext loaded nor do I have the Apple folder. I am new to this community as well. Do I need the AGPMinjector for proper power management on my 5700?...... In the OS I do not have much stutter or lag its very smooth currently but always stutters in game. Could my graphics card be throttling itself because of heat because I never hear the fans ramp up?. Hopefully someone with some more knowledge can shed some light thank you.
Maksim V wrote:Evening. Installed Catalina 10.15.4 on my Ryzen 3600/Asus B450M Plus Gaming/XFX 5700 DD Ultra.
looking through your config plist, I don't see the AGPMinjector kext loaded into the list I see 7 children should be 8. Try pointing to your OC folder again using proper tree.
#56880
I am also having a bit of stuttering but more so in gaming vs anything else. Not that were all supposed to be gaming on Mac but I'm dual-booting windows and HackMac only to find out my Vega 56 is having trouble playing Sims 4 at Max Graphics while in Windows it was no problem at all.
My specs:
Ryzen 7 3700X
Radeon Vega 56
MSI B450I Mini-Itx
#56911
same here + huge GPU RAM leak + windowserver high cpu usage.
Screen Shot 2020-04-27 at 03.52.15.png (2.11 MiB) Viewed 934 times
