by: crokman
#54378
I think modifying system kexts will be my last option.
But now MaciASL returns 6160 error. I will try again
#54379
Remove HDEF. That's for onboard sound and the aml will compile.
by: crokman
#54380
Did it but still with 7mb monitor.
Maybe I have to change something more. To be honest I'm not so confy with sstd dsdt editing
#54381
Apart from modifying the kexts I'm out of ideas. Join the Discord server if you haven't already. There will be someone there with a better idea maybe. https://discord.gg/EfCYAJW
There's a couple people I can think of so if you join make a post in #gpu_support and tag me. I'll get them onto it.
#54382
OK, I am already a member of Discord server!
I will do it.
Just the last try. I will rebuild DeviceProperties with fakeids and will see what happens.
See ya on Discord
In order to close successfully this tread, I post my full working EFI folder, just in case someone will need an help like me!
Shaneee liked this
AMD OSX with Dual boot?
So I had a ryzen system and installed catalina on […]
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
