by: crokman
#54300
I did it but my Mac will recon a 7MB display instead of a fake graphic card.
Do I have to use another ID maybe?
#54301
by: crokman
#54334
I'm back again! I tried following the guide you gave me but, unfortunately nothing changed. My GPU is recon as a 7MB monitor. I used to boot with -raddvi and radpg=15. Now the all the stuffs have a better looking but still lo-res display. pixels are very sharp. I found something about injectATI but I think it's a clover stuff. Am I right?
I used r9 270x fake id (1068 0210 as shown in the guide) and I tried with the original one (1168 0210).
In Mojave I used to use 0x68191002 as fake id. It was another card, I know, but all the VRam was recon.
Any suggestions? I saw something about patching DSDT.. Is it a possible solution?
PS Now keyboard is working fine with IT layout. I had to reboot a couple of times to make the changes effectives.
A couple of photo
UPDATE
I found this method as I told before:
https://www.hackintoshzone.com/files/fi ... 0x-series/
Is it a good solution?
#54369
Are those images with DeviceProperties or the DSDT?
by: crokman
#54371
Those are with device property patched
I'm trying to compile 2 SSDT, one for each video card.
I will post updates as soon as I can.
_______________________________
UPDATE
I setted up ssdt patches and left the fakeid configuration in DeviceProperties.
This is the result:
No kext loaded
Then here the 2 SSDT
Shaneee liked this
#54373
Remove the Device Properties for testing the SSDT.
by: crokman
#54374
Done but still 7MB monitor with no kext loaded for the graphic cards.
Maybe I did some error trying compiling the SSDTs
I tried to follow the guide on GitHub referring to hd7xxx series. On HighSierra and Mojave my GPUs was detected as HD7xxx series 2048MB
#54375
Why are you using IGPU? You should be applying the patches to GFX0
by: crokman
#54376
ok I will edit
#54377
I'm sure that's how it should be... The other option is to manually add your device ID into the kexts themselves. Modifying the system kexts isn't 100% recommended but it "should" work.
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
I have a hp6305 with X740 AMD CPU and a Geforce 31[…]
