by: crokman
#54227
@Shaneee Never heard about that on my mobo! I'm still searching in the user's manual but i can't find anything..
I found this one GPU.DIMM but it's quite normal gpu tweaking..
I will try with npci=0x3000 and I will post some update!
Thanks for your time
npci=0x3000 gave me one more step next to installation but still in panic, as you can see..
#54229
Hmm that's strange. Add cpus=1 as a boot arg to test.
by: crokman
#54232
Unfortunately nothing has changed...
same panic message! do you think is a good idea to disconnect one gpu and set -radvesa or -radoff as bootargs?
#54233
Might be an option yes. Use -radvesa to test. The R9 270 doesn't have native support in macOS so you'd need to fix that once installed. Using vesa mode may allow it to boot.
by: crokman
#54234
No results with -radvesa.
Now I will try with only one gpu
It's the same old story... I have the same panic message..
Just one gpu and a ton of bootags.. Maybe I have to chance some drivers?
#54237
I've asked on the Discord for some suggestions. Either they will reply here or I'll pass on the message.
crokman liked this
by: crokman
#54239
thank you man! I tried some modifications but with no results.. I am stuck in the same panic at the same point.
Any help will be fantastic!
#54240
Try with this config,
by: crokman
#54273
Really thanks for your time @Shaneee!
I have the same panic problem at the same point. You can look at the previous posted photo, it's exactly the same dialog message.
BTW I had to change UUID because it gave me the incompatibility screen after launching installation.
I used something similar to my PC (iMac 18,3) instead of MacPro5,1 as in the config.plist
I used these settings on system information:
MBL C02812310QXJ0PGCB
ROM 11223300 0000
SPN iMac18,3
SSN C02W8TZLJ1GJ
UUID 5EA82FED-2DB3-464D-AF14-FF60B31BBDC6
instead of what you gave me
MBL C07202101J9BH8FB
ROM 112233000000
SPN MacPro5,1
SSN C07H30EQF4MC
UUID 9A75F7D1-E413-4BAD-A5C4-83FE5682D12F
Maybe there's something wrong in it? I really can't undersand why it will not give up and let me install! Damn machine! :lol:
#54275
I altered the SMBios configuration incase it was some incompatibility. This was from a member on Discord,
I've seen that under 10.5 and 10.6 when you boot 32bit kernel on a 64bit firmware/DUET
Which doesn't really make sense considering it's the most recent OS which is all 64bit. The only thing I can suggest is remake the USB with a fresh macOS download and use the EFI I originally uploaded.
Can you share EFI with me? Thank you! Emial:foreve[…]
Use the tool to download 10.15.3 instead of 10.15.[…]
@fabiosun or @Shanne is this the correct guide for[…]
I have a hp6305 with X740 AMD CPU and a Geforce 31[…]
