#54111
Hello, I tried to run macOS Catalina according to the guide available at https://khronokernel-2.gitbook.io/open ... ktop-guide and unfortunately I stopped right after running the installer.
I can't run the network card on the Gigabyte Aorus Elite B450 motherboard - from what I could find in the specification it is Realtek 8118. I tried various kexts, unfortunately none of them works (Realtek8111.kext and Realtek8100.kext). I am doing something wrong, is there a problem with this LAN card?
#54124
bjar wrote: Tue Jan 28, 2020 6:02 pm I have the same mobo and it is working with the 8111 kext.
Can you upload the kext you are using?
#54126
Yeah I will this evening. I can send you my config as well. It took me 8 hours or so to figure everything out before I could get it to boot. Did you happen to get sound to work? Only things I don’t have working is sound and sleep.
Here ya go.
#54136
using the same kext, but lower version
2.2.2
bjar liked this
#54139
bjar wrote: Wed Jan 29, 2020 3:26 am Yeah I will this evening. I can send you my config as well. It took me 8 hours or so to figure everything out before I could get it to boot. Did you happen to get sound to work? Only things I don’t have working is sound and sleep.
Here ya go.
Thank you. This kext worked without problems. Do you recommend any specific wifi / bluetooth module? Earlier I used a tplink t2u v2 usb modem, but unfortunately there are no Catalina drivers for it.
#54154
piter.zaw wrote: Wed Jan 29, 2020 6:23 am
I am not using either. Should be plenty of info here on the forum.
I am trying to resolve my sleep issues following t[…]
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
@teseraph , Hi i'm planning to build the same […]
