by: Apophis
#56443
@James Stoddard, You need to clear NVRAM before booting, otherwise the new csr value will note be applied.
#56480
So, I was able to get past the error I was reporting before in terminal by doing an NVRAM reset. However, when I tried the first method, my CPU shows up as 3.8Ghz; so I'm not sure which line to adjust in BBEdit. Then I tried the second method which was to run some code on terminal from GitHub. That did not work either.
Any more advise? :D
