#52298
First, sorry for my bad english.
I have read Opencore Vanilla Desktop Guide, and setup the config.plist file, and try to install macos 10.15.1.
After boot macos base system in verbose mode, then the screen doesn't show anything anymore, just all black.
I don't understand at all :wtf: :wtf: :wtf: , what happened? What did I missing?
AMD RYZEN 7 2700X
MSI X470 Gaming Plus
ADATA XPG Spectrix D80 RGB 16GB
ASUS TUF Gaming X3 Radeon RX 5700 XT OC edition
Here my EFI
EFI.zip
I edited config.plist again and booted the macos basic system, no longer a black screen, but I got that is a weird screen...
Is that a driver's problem? or, just a cable problem?(I'm using DisplayPort to DVI cable)
Can someone tell me how to fix it....?
Here's edited EFI.
EFI.zip
#52320
Try using HDMI only with no adapters. There seems to be a small bug with the new AMD drivers and appears to be fixed in 10.15.2
sarukomine liked this
#52363
I think I have the same problem. The installation is started. Mouse pointer can move with a weird square, but it cannot click anything. The keyboard can move the cursor but cannot press enter to advance in the installation.
I DID try switch the cable to HDMI (No Adapter) Nothing changed. Any solution?
AMD R9 3900X + Aorus x570 Elite + 5700XT
#52372
padbaht1 wrote:I think I have the same problem. The installation is started. Mouse pointer can move with a weird square, but it cannot click anything. The keyboard can move the cursor but cannot press enter to advance in the installation.
I had the same. after the install it was all good. The screen acts off-centre when installing, but it's actually not. try to go with your mouse to the middle and you'll see hat you actually can select something on that screen. that black square comes up when you're outside of the off-centre screen.
#52413
Shaneee wrote: Sun Nov 10, 2019 1:33 pm Try using HDMI only with no adapters. There seems to be a small bug with the new AMD drivers and appears to be fixed in 10.15.2
I think you are right :thumbup: , this is a problem with new AMD driver, because I downloaded the latest version of mac os (19B88), and finally successfully entered macos base system and installed macos.
EFI, hardware and even cable have not changed...
Thank you for helping. :D
padbaht1 wrote: Tue Nov 12, 2019 4:12 pm I think I have the same problem. The installation is started. Mouse pointer can move with a weird square, but it cannot click anything. The keyboard can move the cursor but cannot press enter to advance in the installation.
Let's try the latest version of macOS (19B88), this version already solved my issue.
#52466
Hi, @Shaneee
My hackintosh that everything is fine, except for Sidecar, I don't know what to do...
I have iPad Pro Third generation, and I logged in the same ac on hackintosh and ipad pro
I'm using BCM943602CS, so bluetooth and wifi both work fine, and I set PlatformInfo> Generic> SystemProductName to iMac19,1 in config.plist.
I think Sidecar should be work but it's not. What step did I missing?
#53299
First I would like to thank you for your EFI, I had spent tons of hour to figure out how to use OpenCore but still cant get it to work. After I used your EFI and hoolaaa...... my hackintosh booted in successfully. :D
I have 1 question, how do I set boot entry automatically? It doesn't boot in until I choose the boot entry, anyway to set it boot in by default ?
#53329
SkySaw wrote:First I would like to thank you for your EFI, I had spent tons of hour to figure out how to use OpenCore but still cant get it to work. After I used your EFI and hoolaaa...... my hackintosh booted in successfully. :D
Could you share the efi folder you used please Im having trouble even booting opencore. Thanks
#53347
it's on the first post , i downloaded it from there
I read the posts and just want to drop in with my […]
Hello I have this kind of hardware: AMD FX-8350 A[…]
Catalina 10.15.4 Update Bug?
Sorry no success that didn't´change anything[…]
Thanks for your answer! This fixed my issue! :thu[…]
