by: nassn
#51745
Hi everyone,
i have successfully completed my Catalina installation.
Here is my hardware information:
Gigabyte Aorus x470 Gaming 7 wifi
Zotac GTX 1070 Ti AMPİ Extreme
Gskill Trident Z DDR4 3200mhz cl14 2 x 8 GB
AMD Ryzen 2700x 3.7 ghz
ViewSonic 42.5' (3860 x 2160)
WD HDD 320 GB (hdd for test catalina)
Bluetooth Onboard
Bios Settings:
Under Peripherals tab
inital display output PCIe 1 Slot
Driver install Steps:
  • Boot with recovery mode with usb efi when you see recovery screen open terminal window. copy and run this command. and reboot your pc from top bar or terminal
    csrutil disable
  • Load with hdd efi from boot disk list , after that choose macOS boot option from clover boot list. Login with your password and open terminal run this command
     sudo mount -uw /
  • Download webdriver-all-versions-app.zip from attachments and run the WebDriver All Versions app and click on Reinstall Driver and then Download Webdriver.
  • After it's done, quit the WebDriver All Versions app and open it again. Click on Existing Webdriver Patching. This requires the Terminal, so give access to it when prompted.
  • Open the Terminal.
    Copy and paste this command:
    sudo chmod -R 755 /Library/Extensions/NVDAStartupWeb.kext
    and press Enter. Enter your password if necessary.
  • Then copy and paste this command:
    sudo chown -R root:wheel /Library/Extensions/NVDAStartupWeb.kext
    and press Enter.
    sudo touch /System/Library/Extensions/ && sudo kextcache -u /
    and press Enter.
  • And the last command to copy and paste:
    sudo touch /Library/Extensions && sudo kextcache -u /
    and press Enter.
Download and install the latest CUDA drivers from here. https://www.nvidia.com/en-us/drivers/cu ... r-archive/
Before the restart , in your clover config NvidiaWeb should be unchecked in System Parameters
Restart again but you should be carefull about your connection cables.
Display cable not worked for me.
if you see black screen after restart , probably your cable is not send signal to your monitor. HDMI work fine on my setup good luck :thumbup:
Chavezfher, Josh Podi liked this
#51753
what the hell !!!!!!!
Seriously ?
this is awesome !
Can you make some test please, I'm very interested in a 1080 Ti
by: Sundhar88
#51754
Do you have acceleration with this web driver?
#51757
You'll get it recognised with full resolution but no acceleration.
Riggs_Martin liked this
by: nassn
#51785
Shaneee wrote: Wed Oct 16, 2019 3:37 pm You'll get it recognised with full resolution but no acceleration.
Yeah you're right Shanee HWAcceleration is not supported :problem: But resolution fixed.A little bit better when you compared to 7 mb graphic memory :thumbup:
by: Bushuu
#53449
Thanks for this dude, the only problem is that 'The application "Webdriver All Versions" can't be opened." is there any chance you could have a look at this for me please?
EDIT:-
Threadripper 1950x
Asus Prime X399
32GB DDR4 3000Mhz (Corsair Vengeance Black)
Gigabyte GTX 1070 G1 Gaming
by: gimpbully
#53556
The binary in the .app is missing executable bits. If you hop into terminal and cd into Webdriver All Versions.app/Contents/MacOS, just 'chmod +x Webdriver\ All\ Versions'
I've got a very similar x570 Taichi & 3950x se[…]
@iGPU , This is awesome, thanks! I'm about to s[…]
thanks for sharing your file. I was struggling for[…]
https://imgur.com/a/Xf9q25f Specs: \[CPU\] \[[…]
