#56816
Hello everyone,
This is my second hackintosh build. I am using Asrock 970 Pro 3 motherboard and AMD FX 4300, Sapphire Radeon RX580 8 GB.
I had a problem during OpenCore initial boot. I cannot move the keyboard cursor. So I cannot choose the installer.
Bu actually, when I remove all my hard drives, the default list will change to "install macos Catalina (external) and it can boot normally until it reach the disk partition, etc.. In the macos disk partition, my keyboard is working there. It's a bit strange.
So my keyboard is not working in the macOS boot selection only .
Which config.plist part I should take a look or change?
I only put these in the EFI Drivers:
  • ApfsDriverLoader.efi
    OpenRuntime.efi
    VboxHfs
And I have already put this kext to my KEXT folder
XLNCUSBFIX
Any help would be appreciated.
