by: YAYAMC
#56293
i have the asus b450m-a motherbord and when i try to install mac os catalina its tell me that i'm dont connect to internet but i do.
if someone know how to fix that please help me, thanks a lot if you do!
by: Blizzard Wind
#56307
do you have rt8111.kext in Others folder or Kext folder if you're using Opencore? Better use Opencore if you're using Clover. Much cleaner and the closest to a real mac
by: YAYAMC
#56358
i am using open core. thank you i will try to add this kext.
i added the kext but now the installation stack on the apple logo and dont load. do i need to change something in the efi folder or in the bios?
